AsslamOAlaikum, can anyone guide me to make radiator fan run when AC is on and keep on automatic when AC is off. Is there any special alteration required (need to goto the electrician) or is it just like minor tweak to run fan direct?
Fan should come on after a while when ac is on.No need to do anything else.Incase it doesn't turn on then there is a problem.
I forgot to mention it's cultus 2010. And it won't turn on with AC. It'll kick just according to the temperature.
U mean it doesn't turn on at all with ac or it turns on after sometime?
I think that works with pressure switch.
It should be a simple diy but I would suggest you to go to the electrician.
It's nothing difficult. An easy circuit with relay will do your job.
Regards
Aik relay lagti hai bas
bro cultus 2010 mei ac k lye alag fan lga hota h..jo compressor on hotay hi on hojata h and remain on until compressor is off
mean while raditor ka fan auto pr kaam kra hota h.
