See an answer by a member which helped me get the reading.
05 shows the peak time tariff A.There is written A in upper right corner.
06 shows the off peak time tariff B.There is written B in upper right corner.
And in all pics you can see RATE B written in left hand lower corner in front of ABC which means that "off peak time tariff B" is active as its day time.If you check this meter after 5 or 6 pm you will note that there will be written RATE A at that time.
There are many other parameters like voltage of all three phases,load etc are also shown in digital meters.ANd this kVarh is I guess for industrial or bulk use.Anyone correct if I am wrong.
