Hi PW friends
**I am facing a problem as i want to use original electronic fuel pump that is mounted in fuel tank with carb. set up in a car but the problem is that the pressure is much than the carb. float to manage . is there any method that i can reduce the pressure.
*should i introduce a return line or reduce the pump speed by introducing a voltage drop ??. please help.
