Brother you will have to grind it down using a sandpaper and a machine sander. Do it bit by bit and do not get too deep in paint. Target the affected area only and use a soft pad dist with 0 size sandpaper and when you get close to the paint use a finer grade sandpaper and sand down the elevated surface with the paint. All the best.
