I need your help to set the clock . I learnt how to set the clock in my previous car...a 2005 accord, but the clock 2009 dash board is different.
post a pictureaccords come in different variants/options
thanks...please see the pics
disconnect and reconnect the battery at 12
Thanks! will try that tomorrow. It is now 7:37 pm in Jamaica
Or maybe 1 : 00 pm depending on what time appears on your clock after reconnecting battery
Highlighted Red Area is your CLOCK button .. You can do clock setting by pressing or hold the button...
look at all the buttons in day light with a closer look, you may find written H : M : R : S some thing light this.I had the same problem on my CL7 but then I found this
OR
Disconnect battery terminal as 12:55 and reconnect it exactly at 1 : 0 0
this is also one of the solutions
The clock is 2 hours ahead so I disconnected it at 1:45pm and reconnected it at 2:00pm. But the clock went back to 4:00pm after a few moments
Thanks everyone for all your suggestions! I will look at the dashboard in the daylight tomorrow to see if the H : M : R : S shows up. Will let you know .....
I also tried pressing and holding the button indicated (clock) above but to no avail!
