[QUOTE=Xulfiqar;4363102]
1 - make sure its always used at normal operating temperature (normal temperature means engine at 85-95C and not dead cold)
3 - make sure the PCV valve and breather are not bad.
Thanks Xulfiqar for your expert advice.
1. For normal temperature, I should keep the engine running for sometime before moving on. If you mean that, how many minutes normally I should do it?
3. I am not aware of PCV valve and breather. Can you post some picture and its location in the car and how can I ensure they are in good condition?
