U will never come to know
It should be written on it ..specifications and remember to get 1 with built in IC regulator ...wen battery is full charged it should stop charging
ok bro thanks
I have done my calculation long time ago!No need to do it again
I don't know that his sub is d2 or D4 (Poster does not mention as well)....!thats why said this......!
If it is D2,Than F2500D will surely bang it way way harder.....!
i know that solid audio has been made into something of an idol here in pakistan. trust me for high end setups it doesnt cut it
its a d4..... meaning no it will not
i think its d4..... becoze 2 positive wires and 2 negatives wires are coming out from the SPL.......
that does not make it D4. it just shows that it is dual voice coil. mention the complete model of the sub
spl 5000 is replaced by spl 3500 3002d4... nw m using it ... and it sounds a bit good ...
@ madhouse .. uploading pics of sub
model TS-W5000SPL
no way :D, replace amp not sub
its a 4 ohm dual voice coil. says right on the sub.
dual voice coils me d2???? and bro spl5000 is with me..... will install it again jub koye acha amp lay lo.... till that i will use spl 3500...
pic of the setup
can any1 tell me 3500 watts spl ko f25d k sath kitnay ohms pay connect kerna chaye... and how.... i combined the positive and negative wires comming from the sub and attached the positve on a positive terminal of the amp and negative at negative terminal... and second wot is the slave and master button for in the amp???
First of all....Please make a proper place for your battery!Secondly,Your 3500 watts spl is D4.....So it cn be either connect @ 8 or @ 2ohms with your amplifier.....Also make a proper tuned enclosure for your sub made from atleast 0.75" MDF......As if i am not wrong your current sub sited in a chipboard enclosure!
So better for you to wire your sub @ 2ohms.....!Just like mention in the pic below....:-
exactly wat i told Haroon, u need 2 CV for it to run on it.
thanks talha bhai and sound master... talha bhai yes i think its made of chekboard...here in peshawar no1 knws how to tune a box... i will change the box... can u give me the proper dimentions for the box.and bro cant ind any other place for the batry ....and the sub is connected as shown in diagram..and yes i will change the batry wiring ...
For proper box dimensions contact splfanatic...
and 1 thing more....when m increasing the volume the bass fants..... at low volume the bass is quite good but by increasing the volume the bass starts decreasing.... wots the problem it could be ???
