You can check the PCV for blockage. Remove it and observe if air is sucked through it with great pressure. The other way to check this valve is through engine oil cap. Remove it and place a tissue paper at opening. Now, observe if it is pulled inward. Make sure it does not fall inside. Well, this method may not work but you can try it.
