Lift the three clips on back with small screw driver, Make sure not to break them if you handle with care. and you will separate the back piece connector.
After separating the back connector you will see two small holes on each side of switch marked in pic with RED arrow.
Insert small screw driver in it to press the clips in it and release the front piece.
