AOA,
Does any brother know the firing order (Spark plug wires and coil connection order) of Santro 1.0L engine.kindly help as following,.
left to right "1, 2, 3, 4 " engine top to down "4, 1, 2, 3" coil
Waiting for experts.
1342 is firing order
Normally 4 cylinder Otto cycle engine firing order is 1342!
is this correct ?
this is second one, is this correct?1st?2nd?
right now it's as first picturei've tried second diagram wiring too, but no difference.
Please reply, EXPERTS...
What about 3 cylinders?
132 is normally for all Japanese cars except charade whose firing order is 123
It uses waste spark technique.1423
thats why is requires a balancer and thats also why its so torquey too
Bro which picture is correct for Hyundai Santro. Quote from above pictures .
If cylinders are, horizontal 1, 2, 3, 4then distributor ports are vertical as follows1234
just tell me, vertical order on distributor, which cylinder will be connected to which distributor port.
1 to 12 to 43 to 24 to 3
1st set is coil2nd set is cyl
its a simple waste spark systemcyl 1 and 4 are companionscyl 2 and 3 are companions
like every other wasted spark engine in the world.
3Clynder firing order 132.
Sorry bro i am technophobe. Plz tell me engine side from left to right and coil top to down setting. Regards
