I purchased a 125f 2022 in blue for use in our colony and small trips to put around in after I just moved to Pakistan.
Overall, my experience is 50/50 with this bike. I will list the pros and cons of my ownership experience.
Day 1 purchasing the bike, it has a rear suspension squeak and front brake noise. Rust began forming on the exhaust silencer, bolts on handlebars and other bolts on the body pieces. Took it back, they were unable to solve the squeak and submitted claim for the rust. Replaced the silencer for us.
Also noticed power was just, not there. Acceleration was subpar compared to my uncles 150 Suzuki and brother in law's 110 pridor. Contacted Honda atlas and was told to take it in for 500 km service at another location.
Took it in at 500kms, performed the service, greased the rear control arm bolt and found a piece of plastic in the front brake caliper. Front brake noise solved, rear suspension squeak was solved for 2 days before returning. The rusty bolts? Painted with a brush and reinstalled.
My front parking light also seems to not work anymore. Can anyone confirm this indeed does have a front parking lamp? It used to work but now it doesn't. Techs are saying it doesn't have one. I know it does, as I would always used it when going to read Maghrib prayer when full beam was not necessary.
1000km service. I put some pressure on the tech's to solve my problem. They removed the entire read suspension assy and found the rear bushing was pressed incorrectly from assembly causing my noise. New bushing and so far it seems to have solved it. It's only been one day though, so we will see. They convinced me the front parking light does not exist so we have left that not working. They also dropped my headlight assy and cracked it. Refuse to fix/replace obviously because 'it was like that already'.
Power is now a lot better. I drove it up to 110 kph forcefully in order to test. Seems good.
Overall, what I like:
Looks, riding position, balance of the bike, easy to ride.
What I don't like:
Quality is poor, cheap material, poorly put together, fuel gauge isn't always accurate.
Overall a decent bike. Would I buy it again? Probably not. If I have no future issues, I may change my verdict. Was actually wanting to go for a gr150 Suzuki, but there was a 3 month wait period. I am also a bit biased as I also own a 1000cc Suzuki which is stuck in Karachi for custom clearance.
