Hi Guys,
I am facing 2 issues,
Issue Number 1
When I cold start the engine, it takes 10 to 15 mins to warm up to 74 degrees. Right after cruising, the temperature drops below 70, the rpm starts rising around 1200-1600, which shouldn't happen, like it shouldn't drop the temperature. I have checked the fan starts at 94, which ensures the temperature sensor is working fine.
Fixes
- changes the temperature sensor.
- Fan is starting at 94.
- changed the thermostat(Kabli) as well.
What could be the reason?
Issue No 2
Sometimes the accelerator pedal doesn't respond, and it gives P2121 TPS or app sensor, and sometimes there is no error, and the pedal won't respond, and when we restart the engine, it works fine, and it's kind of an intermittent issue.
Any thoughts and any guide would be helpful.
