Item(s): IBM THINKPAD 380-ED
Package includes: LAPTOP, A/C CHARGER, Below is the spec sheet i pasted from a website:
ThinkPad 380ED 2635-5AU 2635-6AU 2635-7AU
Processor Type Pentium MMX 166/66 MHz / 64 bit transfer to L2 cache / 64 bit transfer to memory
Processor Upgrade None
L2 cache 256 KB / write-through / direct mapped / 8 ns / synchronous pipelined burst
Diskette Drive Internal 3.5" 1.44 MB / use simultaneously with CD-ROM / on right side
External FDD port None since diskette internal
CD-ROM 5.25" CD-ROM / 8-20x speed / CAV / multi-session / XA / ATAPI / not bootable / not removable / on right side
Preload(see side) Windows 95 OSR2
Available date September 1997
Disk - size / ms 2.1 GB / 13 ms / PIO Mode 4 (2635-5AU)
3.0 GB / 13 ms / PIO Mode 4 (2635-6AU)
5.1 GB / 12 ms / PIO Mode 4 (2635-7AU)
Disk controller EIDE / PCI 2.1 / supports one internal disk / no DMA or busmaster support / not removable / upgrade only by IBM or dealer
Display - size and type 12.1 inch FRSTN color (2635-5AU)
12.1 inch TFT color (2635-6AU, 2635-7AU)
Display - technology (2635-5AU)
SVGA / 640 x 480 or 800 x 600
Dual scan / FRSTN / 150 ms / 70 nits 65,536 sim colors / 35 to 1 contrast
Active Matrix TFT / 75 ms / 100 nits 65,536 simultaneous colors / 100 to 1 contrast ratio
Graphics - controller NeoMagic MagicGraph128ZV (NM2093) /128 bit SVGA accelerator / Zoomed Video support / DDC1 and DDC2B
1.125 MB / DRAM (embedded) / color space conversion and interpolation in X and Y axis / support for DCI, DirectDraw
Graph - arch/data path PCI 2.1 / 32 bit / external SVGA to 1024 x 768 with 256 colors
Graphics - features Simultaneous LCD and CRT / 150 degree tilt
Memory - std / max 16 MB / 80 MB / non-parity / 3.3 volt / EDO
Memory - features 1 socket for one JEDEC 144 pin EDO SO DIMM of 8, 16, 32, or 64 MB / socket accessed from bottom via screw
Keyboard / # of keys Full size alp/num / 85 (6 Fn key functions) / keyboard slope with Port Replicator
External keyboard External keyboard support with option cable 06G8619 or Port Replicator
Pointing/ palm rest TrackPoint III / no drag lock keys
Dimensions 11.8 x 9.2 x 2.4" (260 cubic inches)
Weight 7.0 pounds (3.2 kg)
Battery - type / life Li-Ion / non-intelligent / 2.0 hrs (2635-5AU)
Li-Ion / non-intelligent / 2.5 hrs (2635-6AU, 2635-7AU)
Charge time - on/off 4.2 to 12 hrs / 3.3 hrs
Architecture PCI 2.1 / 32 bit / 33 Mhz (EIDE, graphics, PCMCIA, Port Replicator)
ISA (audio, diskette, serial, parallel, infrared)
Intel Mobile Triton 82430 PCIset / Intel 82371MX PIIX / NS PC87338
Docking Station None
Port Replicator ThinkPad Enhanced Port Replicator, * ThinkPad 560 Port Replicator,ThinkPad 380/385 Port Replicator
PCMCIA slots 2 Type I or 2 Type II or 1 Type III / Zoomed Video support in lower slot /PCMCIA 2.1 compatible / PC Card Standard 95 / Cirrus Logic CL-PD6729 (PCI)
Serial / parallel ports One 9 pin; 16550A / one (IEEE P1284-A, EPP, ECP, bidirectional)
Other Features APM-aware BIOS / Universal AC adapter; barrel (35 or 56 watts)
Video in/out None
MPEG decoder None (software support for MPEG-1 in Windows 95)
Data/fax modem None
Audio support 16 bit audio chip / 20 voice MIDI FM Synthesis / Crystal Semiconductor CS4236
One internal speaker / .5 watt / dial volume control / int mic / full duplex spk/mic
Audio in/out jacks Input/microphone jack (stereo) / output jack (stereo) / no joystick port
Infrared ports Infrared port on left side / IrDA 1.1 compatible / up to 4 Mbps
Security Power-on password / Hard disk password / security keyhole / personalization
Preinstalled software Microsoft Windows 95 OSR2 with applications (listed on right)
NOTE: MINE DOESN'T HAS INFRA RED PORT AND IT HAS 48 MB RAM, AS FOR THE HARD DRIVE, ITS BEEN QUITE A LONG TIME SO I DONT REMEMBER IT EXACTLY, I THINK IT WAS 5 GB.
Price: 4500
Warranty: NO
Dealing method: HAND TO HAND OR ANY SAFE METHOD SUGGESTED BY THE BUYER
Contact method/details: THREAD REPLIES OR PM
Item(s) conditions: Motherboard was short circuited, cuz of electric surge
otherwise it was a very handy laptop..
