double O/D?
what model of gearbox is this? - the ECU you have usually has the basic 4 speed shifts (4th = overdrive) and then final torque converter lockup, Are you calling the lockup as the "double overdrive?"
please install the correct airbox setup for this engine - the insane elbow and the stove pipe type setup is literally ghetto rig extreme.
The cressida even with basic 22R engine can easily achieve 180 km/h with manual 5 spd manual gearbox, With the 7MGE and plain 4 spd auto I have sped ahead of 200 km/h in a 1988 cressida (square block shape).
the 1G-FE is not a very good engine - I prefer the 22R-E over it as it has more punch to it.
