@capsat @Xulfiqar
Hi Mates,
My 97 Japanese Indus Corolla 1.6 GLI Auto 4AFE is making weird loud noise in engine bay, it may be from the transmission, engine, or some pulley/bearing, I'm not sure.
Possible reasons in my mind are:
1- Axle seal was causing the transmission fluid leakage which got very low, I got the seal replaced and drained and refilled the transmission fluid last week, but the noise is still the same. Probably the transmission has been damaged.
2- There is sludge build up in radiator as well. Which makes me think the head gasket is damaged and causing the engine oil mixed with the coolant and the engine noise is loud for the same reason may be.
3- Alternator, power steering, idler pulley or water body pulley/bearing may be damaged and causing the noise.
Could any brother guide me to a pro diagnostic mechanic in Karachi who is available on Sundays as well?
Thanks.
