The safety valve works pretty ok all the time, the thermostat assembly also switches off once water is hot enough (unless some jackass modified it)
The heatrap nipples also work (unless your plumber didnt install them) as they are one way valve for hot side.
I trust you have seen them literally explode like a bomb and take out an entire side of a building like an RPG?
I havent though, the worst I see are leaking ones.
