First of all thankyou for providing us with such comprehensive info. Only if we had more good people like you here.
Coming over to the issue; I own a Mitsibishi Lancer GLX 2006. It is a wonderful car but off late i observed that it was losing power on CNG and knocked if I would take it off from a cold start on CNG, however it would be alright on petrol or after i drove it on petrol for 5-10 minutes or when the engine will reach optimum temperature.
A mechanic told me that i have problem with may crank and cam sensors though i had read my ECU many a times and these sensors never showed up.
A few days back I went to another mechanic and when i told him the problem he said that I might be having a problem with my advancer. Having said that I was able to get hold of a working advancer and when i replaced it, voila! The car started flying again. Improvements:
No knocking after cold start.
I cant feel the difference if i turn the AC on or off.
No difference between petrol and CNG at all!
However, i have a few questions:
How to go about the lights on the advancer, this one which i replaced for testing has its red light permanently on. I will try to adjust the advancer with a screwdriver as you have instructed. In the old advancer, the 1st and second green lights were on, but then the first green light will shut and the red will lit, even if the engine was idling. The same thing repeated even when the mechanic tried to adjust it with a screwdriver, and thus he announced that the advancer has gone bad.
Most importantly, how to go about the 4 little buttons on the advancer? Your post, though self-explanatory has confused me as on some other thread here i saw a post by you where you have given a different setting for the buttons. Please explain.
In the old advancer, only number 2 button was ON (down). Now if number 2 button has connection with the O2 sensor then as per your post, number 3 button should also have been ON and it was not. Please give me as much info as possible because i know the mechanic dude will not be knowing anything about it. Ofcouse Mit Lancer has an O2 sensor, right. (pardon my ignorance).
- Lastly, i have to return the advancer i took from someone, so can someone tell me how much would a Tomasetto CIP 4 plus advancer cost and where can i find the original one in Karachi.
Thanking in advance(r)
