LANDI 100 - makes the electronic control of the point of ignition on vehicles that use natural gas as alternative fuel. This model must operate exclusively on ignition systems that use rotation sensor and SMP (only the inductive type) and the phonic wheel (36-1), (36-2) or (60-2) teeth.
STAP 00 B - designed for vehicles with a carburetor distributor with platinum.
STAP 52 B - is for electronic control of the point of ignition on vehicles that use natural gas as alternative fuel. This model should only be used in ignition systems with a single coil and distributor. We cite as a great example, the majority of the Volkswagen line up to 2001.
STAP 56 B %u2013 it is for electronic control of the point of ignition on vehicles that use natural gas as alternative fuel. This model should only be used in systems equipped with ignition distributor where the ignition coil is coupled to the power module. In such systems, there is not a negative pulse with external access.
STAP 77 B - performs the electronic control of the point of ignition on vehicles that use natural gas as alternative fuel. This model must operate exclusively on ignition systems that use rotation sensor and PMS only (the Hall type) and phonic wheel of 60-2 teeth
STAP 99 B - is for electronic control of the point of ignition on vehicles that use natural gas as alternative fuel. This model should only be used in ignition systems without distributor, double coil and power module attached. In such systems, there are two threads of control, one for each coil, the negative pulse is not available for external access. As an example, we have the ignition coil of GOL POWER, which may be used in some imported vehicles falling in the above case.
