What about fitment of 4age silvertop 20v engine in 86 corolla will it be fit withou alteration?
@capsat @dani_kk @xulfiqar @basitali87 what are your thoughts on this??in my opinion, it is possible but I think it needed some extra alterations as it might not be bolt on fit.
It fiits nice
The only weld work required is on the timing belt side mount, all others line up and bolt on
The axles will fit but you may need different hub n spindles if you find original 4age axles
Rest is very easy job.
If you have EE chassis then it need driving side mount work, otherwise fits easy in AE chassis.Upgrade brakes as well. You can install ae101 front complete disc's...they are bolt on. But if you have early AE chassis then you might need to install bigger steering rack ends. Also change brake booster and master cylinder with it.
@ser_gtr Sprinter rodents will eat her out if you know what i mean
Yes it would be a bolt on swap requiring some tweaks like brackets replacement and axle replacement. Else it will fit bolt on.
