Should require a relay if the horns are 2 wire system like the ones on a old Suzuki.
If it's a single wire earth from body. Theirs a attachment available in the market that can make single wire > 2 separate positive currect wires.
Yes all toyotas with Single horns don't have a provision for a second horn from factory wire cut is required, else the attachment makes life easier. The orignal current is sufficient to power both the horns. Unless you want truck horn sound.
I'm driving a Honda City before 2021 it came with a single horn but has a provision/ Wire for another horn too.
Did the same for my Suzuki Cultus sliced the original wire made connections added a Bosch set of horns
