Finally I m back with some interesting experimental results + video as a proof
The back EMF spike glitch was resolved by removing the noise suppressors from the device. The IFT device performed well as expected, it modified the Injector width (Rich/Lean by 20%) as it is designed for no errors nothing smooth engine running.
Guys this device is useless because as i increased the injector width the ECU automatically reduced the injector width to cancel out the net effect vice versa. It can be seen in the Scope snapshots or its more visible in the Video.
Intelligent Fuel Trimer - Video Dailymotion
Conclusion
ECU cancels out the effect of this device in order to achieve an optimal AFR via O2 sensor. I just wasted my 25 days on this Device. Its proved that its almost impossible to alter the AFR by modifying the injector width. A complete failure . . .
This Device can be used in Sequential Injection CNG kit to drive the CNG Injectors by using the same OEM Gasoline ECU.
