Dear All... I wana give you some basic info about Inverters ACs which may help u to decide the brand and products at the time of buying New Units.
First undestand the basic technology, there are two types of technology units available in inverters, one is based on fast cooling hence these units always go to their peak Amperes regardless the temp difference between your set temp and the Room temp and consumes more energy... The second type ACs always increase their ampere based on the temp difference between the set temp and Room temp hence consumes lesser energy but little slower cooling effects.
If u need faster cooling and no issue of the bill amount, go for type-1 but if you are more concerned over the bills, go for type-2..
Type-1 examples are Haier, Dawlance, TCL, Gree, Orient Jupiter, Venus, Atlantic etc.
Some of the Type-2 brands and model series are like Orient Ultron All models, homage 75% models, same in Kenwood as in Homage, PEL some models like Ace series and others. You can select these units by identifying the Remotes.. All have similar Remote with same Remote software but with different brand names.
Orient Ultron Classic model is the gold standard for these units as they were first to introduce it. Take Ultron Classic, Divine remote as standard and you will find the same in different brands. (Back end/OEM Manufacturer is same). Check these remotes on google, u will find it.
ACs remotes tells the whole story.
I suggest you all should use the Digital Ampere meters very near to your ACs indoor units so you can always know what ur AC is consuming (amperes) at every glance. You can control the usage by temp settings and using ECHO mode of ur AC if available.
I will share some more info with you... And request u to pls share these details with other brothers as well. So they can also understand the same.
