Salam everybody,Best Air Conditioner with the economical price range and best output is Gree Dual Inverter AC.It is around 65K to 70K but it's worth it, 2 years warranty and minimum electricity consumption makes it the best product for this summer.
I bought Gree Inverter 1.5 Model GS-18UITH3/0 but i noticed that its compressor turn off and starts automatically after some interval for few times. Is it normal behaviour or something wrong with it.
It should not shutdown but slowdown.
thank you brother
Aoa, in my area voltages are very low around 160, if i will buy 1.5ton gree Ac...it will work fine or not...although it needs 150v but u know high current demand may cause problem, what will you suggest?
plz mention the price of your panasonic AC
GREE will work fine on 160v, just make sure your cables are not too thin and can handle up to 14-15amps
Bhai jab inverter slow hota hai to cooling b kam ho jati hai kia????
mein nay kal lgwaya hai gree G10 Inverter.raat ko mein nay 11 bajay on kiya aur 20 mins kay baad iss nay apna desired temp achieve kar liya (26 c) magr compressor switch off nahin hoa balkay slow hogaya magr cooling same thi but slow pace mein.ap apna chk karwaein switch off nahin hona chaiye.
me b switch off nai hota bus slow hota hai cooling to hoti hai but jese starting pe hoti hai wese nai thori kam hoti hai air throw b kam ho jati hai, aur apke room ka size kia hai ???
My room size is 10*14 but ac compressor shut off in morning not in night
Bro raat ko mera ac theek rahta ha morning may shut down observe kia ha ma nay
kya inverter ac ka compressor start honay kay bad aik bar bhi band nahi hota in 10 hours i observe few shut down in only morning time
aoa, my room size is 150sqft and height is 10ft, top floor although sides are covered only roof is fully exposed to sun... kindly suggest me tonnage of AC. for my room..Thanks
Room 10x10 required one ton 10x15 1.5 ton
At start it takes 8 amps almost but when room get cool up to set temp it's reduce up to 3 amps then continue till ac off
AOA
i want to buy a 1ton AC can any one share about PEL 1ton Inverter .
i have purchased Pel inverter o cool last month from daraz sale and so far its been working good no issue's so far comes with 5 year warranty while the inveter o sense comes with 10 years warranty.
any one knows ac installer who has vacuum pump in karachi ? Please reply
what is vacuum pump and why we need it???? please help
