4mm wire is more then enough for upto 1.5 tons.
it depends on where the main plug wire is connected. if the main wire is connected to the outer. then you can even use 2.5mm wire going to the inner unit. as the heavy load is in the outer unit.
use 3 core flexible type wire. earth, neutral, live. pakistan cable is good.
