Updates On Candy 1TonDC-INVRTR
Pros:
Decent Quality In V Decent Price .got it on promotion
Unit Using Latest R32 Refrigerant
Dual Layer Condenser design For R32
Consumes Quiet Decent Ampere. 28 Degrees Maintained..1st it kicks to high then settle around 1.9-2.08 amps...then eventually drops to 0.15-0.25 where outdoor is almost completely shutdown.. then it starts back as needed
Simple Operating Remote
13,000 BTU
Well Designed and Assembled Outdoor unit as i can see after opening cover..there were plenty of shielding/padding used to avoid heat and vibration . couldn't see compressor as it was way too inside but i am 95% sure its Highly (Hitachi Shinghai )
Gold Fin Condensor/Evaporator
Cons
Inner Could Be More Better In Terms Of Quality/Design
Air Throw Is Just OK . Could Be Better. a bit noisy loose type of swing at 1st operation on still...
No Additional Smart Features Like Wifi/Ambient Temp Display/Remote Sense Etc. not required actually in most cases.
R32 Had High Discharge Temp So Watch Out Installing Outer Unit In Tight/congested Closed Places As It Would Heat up Alot In That Case and may cause thermal tripping of compressor
Conclusion: In This Price Its A Basic Inverter Which Serves Purpose Well...Impressive Result With Good Energy Saving as any good inverter. decent operational noise
Overall in this Price. Great Unit
