Interesting. So this stands for our Pakistani fuel too? Because people suggest changing from 70,000 km to 150,000 km.
Also, any tests that can be done to know whether fuel filter is blocked? While the drive and pick is normal, Car one night decided not to start on me. It just appeared like there's no fuel. After cranking the engine every few minutes for 30 minutes, engine started but just barely. A few pedal pushes and it was normal. Never had the issue again since then.
So someone suggested it happened because of a fuel filter.
P.S. I have been using Shell Ultra 5W-40 oil since I got the car at 20k. No oil reduction and engine seems to be okay. Should I keep using 5W-40 or change to something else now considering the 150k run time?
