you mentioned beast, i mentioned the tube frame.
hood removal serves no purpose as such.
what is really necessary is that your axles line up with the gearbox perfectly horizontal. and at that point, the oil sump (or lowest point of the engine) must have sufficient ground clearance to make the car driveable without any problems. consider shallow oil sumps and Steel plate under shield for this purpose.
once this is done, then turn your focus to whether hood needs to be removed, cut or what ever.
