Salaam
"I recently bought a 2015 Honda Shuttle GP7 with 135,000 km on the odometer (same engine as the Honda Fit). I changed the engine oil and the clutch actuator oil (DOT 4) for the first time. However, after the oil change, the car doesn't feel the same. While it drives fine at normal speeds, it seems like the gears are shifting later than before, and I have to press the accelerator pedal harder than usual. Has anyone else experienced this issue or has any idea what might be causing it or you can solve it"
