I checked my '88 Civic's engine code and it said "D15B". I looked it up on wikipedia and it says:
D15B
Found in:
1988 Honda CRX 1.5X (rare)
1990 Honda Civic 25XXT Formula (Japanese Market)
Honda Civic Ferio MX (Japanese Market) EG8
1998?2001 Honda Capa GA4 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm ? 84.5 mm (2.95 in ? 3.33 in)
Compression : 9.2:1
Power : 103 hp (77.23 kW, 105 PS) at 6,800 rpm
Torque : 14.1 kgm (133.4 Nm) at 5,200 rpm
Rev limiter : 7,200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : Twin carburetor PGM-CARB/fuel injected
D15B VTEC
Found in:
1992?1995 Honda Civic Vti (Japanese Market)
1992?1998 Honda CRX DelSol (Japanese Market)
Bore and Stroke :75,0?84,5 mm
Rod Length : 137 mm
Rod/Stroke : 1.63
Compression : 9.3:1
Power : 130 PS (96 kW; 128 hp) at 6,800 rpm[7]
Torque: 14.1 kg?m (138 N?m) at 5,200 rpm[7]
VTEC switch over : 4,800 rpm
Redline : 7,200 rpm
Rev-limiter : 7,200 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
Fuel Control : OBD-1
Head Code : P08
ECU Code: P08 (small case ECU)***
Honda D engine - Wikipedia, the free encyclopedia
I dont think its the VTEC version but I dont have much knowledge in this regard so I thought I might as well ask you guys. As it says above in the first D15B part, it should have Dual Carburetors. But I cant figure out if my engine has dual carbs or not neither can I figure out if its VTEC or not. Also, how good is this engine? Pictures attached, Let me know if you want any more pictures of a specific area. Any help would be much appreciated! Thanks!
