Hello Aoa.I recently got a Vezel Awd 2015.When i went to some dealership the guy told me that vezel is not good for northern areas as the transmission heatsup.I want expert opinions on it.And also need some info for the actuator fluid.The guy whoi bought the car from told me not to change thr gear oil of the car at all even if someone tells you to.He said that the original gear oil would work perfectly.
Gear oil MUST be changed at stipulated intervals, otherwise your transmission will die an early death. I know of 660CC automatic kei cars going to Northern areas so it shouldn't be a problem for Vezel.
