I'm having brake issues with my cultus as I push the brake pedal the car slips from the back which is very dangerous anybody can help me out , I live in Islamabad. can it be converted into ABS or any other options
It doesn't need abs... Whats the condition of tyres... Are they worn out?
What about rear brake shoes... Are they set right or too tight?
The tires are brand new and I have replaced the brake pads recently idk what is happening
I had the same issue with mine what i did was changed front brake pads and rear brake drum leather with i guess its callled mk brand with yellow packaging not with the chinese cheap ones.... Then i changed the brake oil...but after all this there was stability problem on high speed so got the rear alignment done and problem solved.... Also check out the break serva and your tyres condtion
slip from backdo you mean it tails out from either of the rear end on braking
Yes exactly
