BENELLI TNT 250 SPECIFICATIONS
[TABLE="class: table table-striped vehicle-specs, width: 100%"]
[TR]
[TD="colspan: 2"][h=5]ENGINE, POWER & TORQUE[/h][/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Displacement[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]249 cc[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Maximum Power[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]28.16 BHP @ 9800 rpm[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Maximum Torque[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]21.61 NM @ 8000 rpm[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Engine Description[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]249cc, Single cylinder, 4-stroke, 4-valve, Liquid-cooled, DOHC[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Cooling[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]Liquid Cooled[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Fuel System[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]Electronic Fuel Injection[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Lubrication[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]Wet Sump[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Compression Ratio[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]11.2 : 1[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Bore[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]61.2 mm[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Stroke[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]72 mm[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Number of Cylinders[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]1[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Power-to-weight Ratio[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]177.10 BHP per tonne[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Torque-to-Weight Ratio[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]135.91 NM per tonne[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Specific Output[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]113.09 BHP per litre[/TD]
[/TR]
[TR]
[TD="bgcolor: #F9F9F9, colspan: 2"][h=5]TRANSMISSION[/h][/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Gearbox[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]6-speed Transmission[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Clutch[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]Multi-disc in oil bath[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Final Drive[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]Chain[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Gear Pattern[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]1 - Down, 5 - Up[/TD]
[/TR]
[TR]
[TD="colspan: 2"][h=5]BRAKES[/h][/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Front Brake[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]385mm Petal Disc[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Rear Brake[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]318mm Petal Disc[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Anti-lock Braking System (ABS)[/TD]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"][h=5]SUSPENSION[/h][/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6, bgcolor: #F9F9F9"]Front Suspension[/TD]
[TD="class: specs-value col-md-5 col-xs-6, bgcolor: #F9F9F9"]Inverted Telescopic Forks[/TD]
[/TR]
[TR]
[TD="class: specs-label col-md-7 col-xs-6"]Rear Suspension[/TD]
[TD="class: specs-value col-md-5 col-xs-6"]Mono Shock Absorber[/TD]
[/TR]
[/TABLE]
