I'm facing problem of bad fuel average, it drops to almost 7,8 km/L. There's no error, i cleaned Plugs, Throttle and everything nothing helped.
fill the tank with hi octane and reset the avg then check.. also how much do you drive daily? and is there any reduction in pick etc.
Yes there's reduction in pick.I tried hi octane it get better for a while but rn it's still getting same 7,8 km/L.
hmm.. as your car is new so cat converter being choked is out of question .. i would suggest to take it to honda showroom and tell them to test drive the car to diagnose the issue they will tell you if the cars fine or not and also about the fuel avg sometimes when you do short trips the avg decreases but gets better when you take it on longer journeys so either of these two should rectify the issue also check air filter ,,honda uses oil coated filter which gets choked earlier compared to normal air filters so this also may be the reason for reduction in pick.
Honda dealership is such a mess.I don't suggest anyone to go to dealership.Thanks for the advise I will change my air filter.
Which city are you from?
Try contacting the head office they would recommend you a better 3s dealership. Plenty of experts at lahore
AoA did you fix your issue as I'm having the same problem max 6.5 something even on high octane
