Here is the tub and installation in my basement en-suite. In the last 7 years, I have used it as a jacuzzi twice.
1. Water is expensive.
2. Takes a while to fill up and water loses heat.
I do use the tub daily for shower as I have a shower mounted on the wall separately.
It is a chinese unit, and the quality shows. some fittings went bad after 5 years. there is a bit of bubbling on a couple of spots.
I am not sure, how it will react to pakistani cleaning solutions.
I will recommend a single person jacuzzi with certain conditions. if you have a family member that can benefit from hot water baths i.e. arthritis etc. and water supply will not be a problem, also buy the unit that has a built in water heater/warmer so that the water does not get cold in a little while.
it is a nice experience once in a while if one can deal with the hassle.
For a guest washroom, it looks fancy (sho-sha) as long as there is a seperate shower.
