Rear bearing replacement was correct only change those parts which needs special attention.
For the packing you dont had any room to drive on 160km/h
That you need stability thus no need to go for bigger tyres.
For disc resurfacing this is the correct name for it is needed when disc plate assembly has deep lines which cant be removed by normal sanding so no need to worry about it too.
