As the temp got upOil started to dripRepair did not work for meHad to get a kabli oil pan
so 0w-20 solved problem of oil reduction issue ..?
If u r asking meNo no fix.jo marzi kar lo1kr will burn oilTried all engine grades.Currently on 10w 40Top up 500ml after 2000kms
ok, when do you change the oil, after 4000km? and which brand 10w-40 oil?
for how much and from where?
Last tried total 10-40Now on Shell 10-403500km max
13-15000Khoo or mithu khan running rateRest all depends on bargaining skills n how deep inside market u go searching
so shell 10-40 yellow packing is giving you the maximum interval for the next oil change
I had same shape passo with newer 1KR. Thankfully it did not reduce any oil till I sold it. Was using 0W-20.
testing it for the first time right nowwill update
1KR will start to bugging around 100,000 km mileage and above kitni chali thi?waisay i also head 13/14 model doesnt hv much of this complain
I sold it at 29k genuine. I believe the final facelift / revision came in 2014 till it was discontinued. The 1KR that the revised version has is very similar to the one currently featured in the new shape passo.
my cars auction sheet was 55,000car showroom guys reversed it to 22,000at the time of purchase
now 100,000 +
Engine design was improved in 2014+ models. They aren't as dirty nor are they as prone to burn oil as pre 2014 models
yeah
the improved 1kr that comes after '14 Vitz (not sure which Passo) does not seem to have oil burning issue.
Previous models all burn oil after 60-70k KM.
AgreedAfter mid 2014 they facelifted vitz and the engine was redesigned The engine oil capacity was reduced to 2.8 litres from 3.1 with filter and oil burning issue is no more. Passo also got same engine in 2014 end.
@AkbarGr8 ,
Dear Akbar Sb,
Please share the 1KR repair manual @ khawaraliz@hotmail.com or whatsapp at 0333-3002323
If you can get hold of an ILSAC GF-6 / 6A oil, this may reduce the consumption. Most of the oils are of GF-5 standard.
I think I have the passo repair manual and not the 1KR - car is now sold.
ok if you have manual link then please share.
may b ring/piston ka kaam pending ho is waja say burn kr rai o
