Try to get the carb adjusted. Go to a good mechanic who knows how to adjust carb's as most of the mechanics forgot how to work on carburators due to CNG :p.
If nothing work only option will be to buy a brand new or used carb which is never repaired or adjusted and you will get around 15 kmpl.
Running rich means there is a ratio in which air and fuel is mixed for burnin when this ratio is not correct and more fuel is sent than air its called a rich mixture and if more air and less fuel than its a lean mixture. Both are not good.
