Its electrics should be checked thoroughly especially switch and ignition wiring. Radiator fan should also be checked and convert it to auto if possible.If not keep a spare fan. As your car would be running it direct and it may burn its motor on this long journey.
You should keep some spares like fan belt, fuses in Car.
And I would recommend flush its cooling system too as it would be running Water as coolant.
