KENWOOD KAC 8152D CLASS D MONO AMPLIFIER
Class-D Monoblock Amplifier
- Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
- Variable Input Sensitivity: 200mV - 5V
- Phase Shift: 0? / 180?
- Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
High- and Low-Level Inputs
- 2 Ohm Stable
- RMS Power Output:
- 300 watts x 1 chan. @ 4 ohms
- 550 watts x 1 chan. @ 2 ohms
- Preamp Outputs: 1 Pair
- Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
Dimensions: 15" L x 11-5/16" W x 2-3/8" H
A very power efficient amp could power 2 normal subs easily Ive used a pioneer spl 3500w with this with no problems minimal current draw i was running spl on a 40amp dry battery in my santro on this amp. Condition of this amp is very good & it works like a charm.
KENWOOD KAC 746 4 CHANNEL POWER AMPLIFIER
Class A/B multichannel amplifier
Max. power output 70W X 4 (4Q)
- 35W x 4 at 4Q 14.4V (0.08% THD) RMS power output - 50W X 4 at 1Q 14.4V (0.8% THD) RMS power output
- Variable input sensitivity (0.15 to 4V)
- Built in Variable Low-pass filter (50Hz - 20QHz)
- Built in Variable High-pass filter (50Hz - 200Hz)
- Gold Plated Input / Output Terminal
- Tri-mode operation
- Protection Indicator
- Power MOSFET Switching Power Supply
This is an old school very reliable amp that became available in 1999. Very warm and full sound can drive a sub and 2 speakers or 4 speakers. Provides good clean power and is in decent visual condition and works flawlessly.
Interested parties may reach me at 03138479777 as im quite lazy in PM & updating the thread.
