I have to buy inverter ac on 12 months installments so I opted for this 0 markup scheme.
Is Kenwood worth buying and is the price in the brochure correct. Some one told me that these models are cheaper in the market
And which model should I buy ?
Price is on the hogher side atleast by 6k. Check local market first. Don't fall into 0% markup trap too.
bhai which model you are using please share you exp???? i have recently install eInverter pro but facing a that if i set the temp at 26c so after achieve the desire temp its slow even you feel humidity & sweating , are you facing this kind of issue??? please help
Bank Alfalah even charges more so HBL is good. I know because i have both cards and i compared options from both. However the plus side for bank Alfalah was that they were giving for 18 months markup free as compared to 12 months for HBL.
For what price did you purchase it ?
I have purchased it from faysal bank for same price as above but at 18 month installment
kenwood is here in karachi at 46-47k with 1.5k installation
which model at 46-47k???? inverter????
yes inverter 1 ton in local market, Gree is the hottest selling item and got that at 50k plus 1.5k with installation and 500 for delivery.
Nai bhai, normally i set it to 26 and keep all the night but problem remain as it is, after complaint company guy was just with me and after checking he will change the pcb now bcoz there is pcb issue that he will not provide the current to set at 26 after desire temp...
Is there any difference between the 2 models ?
one say 75% power saving and the other says 60% ?
Which one should i buy?
And what are your opinions about Orient ultron plus (Gold Fin) is it better thn these kenwoods ?
I think you need to go for Orient... as per my opinion because kenwood have some problems and my frnd using orient and he is satisfy to use it....
AOA bhai have purchased any ac???? if yes which model ad brand???
What is pcb
