brother check your thermostat valve. please ensure that radiator fan works in automatic configuration. Also your thermostat valve should be ok. in khyber usually radiator fan runs when the AC is turned on which is ok.
u got to have coolant in the radiator.
also check if the AC bearing and compressor are good and are not causing extra load on the engine.
serpentine or multiflow condensor is not directly related to engine heatup but can be one of the reasons.
do share pics of the setup. also ensure that AC thermostat is ok and have enough gas in it.
sometimes AC compressor needs its specific oil topup to run smoothly. AC guys can guide you on that too.
