It's giving me a such low mileage only 60 KM after Full cylinder no leakage Any expert Please ?
How did you checked the leakages?How is the drive?
I took it to mechanic Cng he checked with surf water no bubbles he said drive is fine and missing on Cng after some race it get fine.But giving a such low mileage
Waiting for your reply...
does it have a super charger? or fmic?
What are these ?
Service the Cylinder and the CNG Kit.
go to suzuki motors regarding cng tuning. dont go to ustaads, if it doesnt help then go for cng cylinder +kit cleaning
Ok Sure I'll
If all the cng is passing through your engine, your tail pipe (silencer) must have black carbon soot inside it... Check it with your finger.
Could be due to faulty CNG reducer kit...
How to fix it ?
No one Any one there ?
check these thingsGas tunning check leaksclean ur kit
Check the leakage while the engine is running there must be leakage while the valve is open
Sent from my GT-I9105 using PW Forums mobile app
Valve is switched off ! No leakage may be any other reason ? Pl tell me
Any one please ?
Ok brother once i faced same problem...In few km i burnt my half cylinder! when i trace the problem...Air intake is in higher volume caused by my new air filter....i put back my old filter and adjust knobs acording to the requirements and peace of mind about mileage.....I think you tuned your vehicle for petrol and "Ustad" set it on Petrol .....!
clean your CNG tank as there would be oil in your tank...
Bro i think you drive your car in streets mostly which have speed breakers avoid un-necessory use of the car....
It's better for Cng will wait and see any good mechanic .
Reliable cheaper mechanic for cng car in karachi any one ?
