Bhai if you want liqui moly waale mazay in cheaper rates, get any mineral oil 10w40 from a reliable dealership zic, shell pump etc and stick to it. On top of that buy a bottle of liqui moly engine oil additive (mos2), this additive will cost you around 900 rupees and will be used for two oil changes, half of the bottle will be added along with your engine oil in the first oil change, the remaining half will be added in the second oil change (after around 3000km).
MOS2 will add a layer of molybdenum on your engine's internal, reducing friction, making it smoother and improving its lifespan.
Liquimoly oils already have this they are awesome but expensive.
