Converted tail lights into led Ones....really easy....step by step procedure is below
TAIL LIGHTS HISTORY: https://www.pakwheels.com/forums/d-i-y-projects/182101-diy-khyber-tail-light-cleaning-easy-do
Brought this LED strip avalible these days ion various shapes in electronic markets...brought from hall rd, lhr
then cut the strip into required lengths..the strip could be cut after a gap of there leds
used pcd board as base as it can resists the heat generated by leds.. and other plastic board can be use keeping in veiw the heat factor....cut the board into segments
used double tape to attach the stips to my so called base :P...But later on i replace double tape with magic epoxy caz the tape buckled due to little heat of leds...elfy wasnt a good idea..magic epoxy worked
fixed all the strips...the top two and last one made the parking lights...and middle one was brake light
very nice led strip prize plz
the led strip costed Rs 380( 1 meter long) , used two strips one for left n one for right...so together Rs 760
Soldered .....
Soldered the wires too...middle strips brake light remaining parking...
Replaced double tape with magic epoxy ....took more time
Make the connections and there u go..parking and brake....yupeee
Fixed the cover back with silicon and there it is
are more pics coming?good going bro (y)
Difference btw left and right.....
Its so easy and cheap and ppl on PW are charging around 5k :-#
Hope u like is....it looks better from naked eye
can u post only indicator and reverse lights in process?
more..
Havent made the reverse and indicator...i kept them simple...plz mind that the flashing frequency of indicator is set according to incandecent bulb....whereas frequency for leds is diff so u need to put some capacitor sort of stuff maybe while making indicators...so i kept them simple
i can show u the wiring if u want me to
got it bro u seem an electrical eng to me (by pcb board)is it possible to make it for a cultus old lights too???
haha ......engr thats a secret..
yes it can be made...i used simple led strips to stay away from soldering maximum....if someone wants his own design then he can make will bulk leds resistors and alot of soldering plus cost goes to well over 2k....however i used this caz firstly its cheap and all the leds are at even spacing...whereas the custom made look fakish due to uneven spacing and distored angles..
If u put clear lens outside, leds would be more visible
