using machined bolts only provide temporary solution, the camber gets disturbed after passing through pot holes at high speed. Either get the camber adjustment made but widening the bolt hole on the shock or get it adjusted through attaching the camber adjustment press on the shock.
i recommend widening the bolt hole on shock, as these presses are notorious for bending the shock shaft.
