Total cost for engine overhaul RS. 47,140/-
Total Part's cost RS. 27,210/-
ART Pistons RS. 1950/-
NPR Rings RS. 1400/-
TAIHO main and big end bearing RS. 1200/-
TAIHO Thrust washer RS. 270/-
Fuji valve's RS. 1600/-
Kansai valve guides RS. 380/-
Musashi valve seals RS. 310/-
Rockers (used) RS. 2200/-
UNITA Timing belt RS. 350/-
NTN Timing belt bearing RS. 1100/-
GMB Water pump RS. 1300/-
NOK Timing/Main seals RS. 350/-
KGK Overhauling kit (without head gasket) RS. 800/-
SGP Head Gasket RS. 2500/-
FCC Clutch kit+ NTN Clutch bearing RS. 6600/-
NACHI Flywheel bearing RS. 350/-
Japanese Mechanical fuel pump RS. 2400/-
APCO Carburetor kit RS. 950/-
Coolant metal pipes RS. 300/-, 150/-
Coolant rubber pipes RS. 250/-, 200/-, 150/-
Guard Oil filter RS. 150/-
Fluids total cost RS. 5630/-
Toyota LLC 4 liter RS. 2400/-
ZIC Gear oil 3 liter RS. 1710/-
Total 20W-40 Engine oil 4 liter RS. 1520/-
(Mechanic used this motorcycle engine oil and said me to change it after 100 km along with oil filter. His reason behind using motorcycle oil was that it doesn't have any friction modifiers and also has good amount of ZDDP.... He said me to use ZIC X7000 diesel engine oil 10W-40 API-SL afterwards instead of SGO)
Labour.
Mechanic RS. 10,000/-
Machinist RS. 4300/-
In Mechanic labour Carburetor service and distributor service is also included and he also used Toyota oil pan sealer from his own part's that is also included in labour.
Rest no Silicone OR Curil was used during assembly all the gaskets were installed dry except the oil pan gasket on which he used Toyota oil pan sealer.
Machinist labour also includes Flywheel machining. Head and block surface didn't needed any resurfacing it was just polished.
