My Khyber's engine is leaking a very minute amount of engine oil.
I changed the chamber gasket but issue was not resolved. Timings seals were leaking, they were also replaced but there is still some leakage/seepage. On close inspection, mechanic said that it is oil pump line which is leaking through head gasket and now head will be opened and head gasket will be replaced.
My car's engine was overhauled around four years ago and it has been driven 47,000 Kms after that.
Now, when the head would be opened, is it a good idea to change the valve seals as well? Because in later stage if they need replacement, the labor cost is quite high for this task.
