I have khyber 2000. Its speedometer was dim. I have seen many thread but non actually guide the process of cleaning from step 1.
Today I with my brother took the challenge and DIY speedometer cleaning. I also changed the default green lights with red ones.
Hope you guys like it
Removed the horn cover to remove steering
Then removed the housing.Easy job.Just 4 simple screws.
These screws would free the meter. Also show in grip which is attached at the back of buttons.(lights)
First the housing and buttons
Back of buttons. 2 more screws to unscrew
Buttons gone.Dont forget to press buttons to take the switch off from the housing
Small glass under the switch.Needs cleaning.
Button. Press it and then unscrew.It has small spring under it.Dont worry it wont fly away.Spring is fixed.
