I just changed my Cars Transmission Fluid ATF-KIXXX Mira 2009. After this my car started to shift bit earlier and at constant speed i feel knocking sound from engine. sound is like when petrol quality is poor but i tried High-Octane, but still knocking sound is coming On Constant speed, not just when car shifts.
I need Help to work this out. Tell me if my car needs any Computerized Tuning or anything.
Thanks.
i hope u did not pour in non cvt ATF in a CVT box
2009 Mira it should be CVT you should have poured toyota cvt-f
Mira 2009 Straight Gear Box is ATF Not CVT
I guess you have put in wrong grade of gear oil plz chk it and get it chnaged asap .. plus check gear oil cooler is working fine it could also cause knocking
It Can Just Be Your Gearbox Part Failure Causing This Sound Or A Wrong ATF Leading To This
Make 100% Sure You Used Correct Fluid ...!
100% bro i pour the correct fluid
did you read the manual ?
what does the gear say, P R N D S B OR P R N D 2 L ?
ND2L needs ATF Dexron III, use ZIC, quantity is 3L .
the other one needs CVT
He says he can feel the gear shifts, so its definitely not a CVT.
