Anyone have an idea what it could be? (Video link provided) Usual suspects are connecting rod bearings or crank main bearings. However this sound is very loud on cold engine and almost disappears when the engine is warm, which is strange. Also the engine has no symptoms of power loss or other issues so far nor any oil consumption nor any loss in oil pressure.
What could be ways to determine the source of the noise for sure.
I tried to remove the injector/spark plug connector of each cylinder one by one but the sound remains there regardless of which cylinder is disabled.
I've tried to determine for any play in the connecting rods by removing the sparks plugs, inserting a metal rod into the combustion chamber, and keeping the piston just past the TDC position. Then I tried to push the piston down to check if any play or click sound could be heard, but there was none.
I don't have the time currently to drop the crankcase and inspect the bottom end. Does anyone have any idea how else to check without disassembling the engine?
https://drive.google.com/file/d/1gO0xL6J6oolWMSzkQvYmhKUdkNbcwCrs/view?usp=sharing
